ANNIN ROBOTICS
0
  • HOME
  • TUTORIALS
  • DOWNLOADS
  • THIRD-PARTY SOFTWARE
  • ROBOT KITS
  • FORUM
  • BLOG
  • CONTACT
  • More
    Use tab to navigate through the menu items.
    To see this working, head to your live site.
    • Categories
    • All Posts
    • My Posts
    jasonzzpro
    Feb 03, 2021
    I strictly followed the manual and checked the wiring many times, but I don’t know why this prompt appears.
    in Questions
    10 answers8 replies
    0
    1
    Kstan Simit
    Feb 03, 2021
    I think need troubleshoot from few aspect, lets start from encoder:
    1. e-stop, manual put position all 6 joint rest position
    2. switch to calibration tab, click "Calibrate @ Rest Position", make sure all J1-J6 no disable encoder (Uncheck Jx Open Loop)
    3. Click "Save Calibration Data"
    4. Switch back to "Main Control" Tab
    5. remain e-stop, move J1 to different location, double check "Current Angle" of J1 follow change accordingly?
    6. repeat step 5 to another 5 joint.
    If above step all reflect proper value change, mean your encoder work well. Try robot see it work well?
    if is same, try
    a. repeat step 1,2,3 with all J1-J6 Open Loop selected
    b. back to main control tab and jog J1=J6 again.
    By right you wont have issue under open loop environment. You may come back to us after your troubleshooting
    1
    jasonzzpro
    Feb 03, 2021
    all the way tried, the same issue
    1
    Kstan Simit
    Feb 03, 2021
    you try manually jog joint without run program?
    beside, you not yet inform whether your J1-J6 encoder detect value properly or not
    1
    jasonzzpro
    Feb 03, 2021
    After power on, I can’t move the joint manually, but after power off, I can move the joint by hand
    "beside, you not yet inform whether your J1-J6 encoder detect value properly or not" where for watch the value?
    1
    jasonzzpro
    Feb 03, 2021
    please help me
    1
    Kstan Simit
    Feb 03, 2021
    sorry, previous post the video can't go in. I put at you tube instead
    1
    jasonzzpro
    Feb 03, 2021
    Hi, Kstan, I Do these steps.
    but the “Main Control ”Tab J1 J2 J3 J4 J5 J6 "Current Angle" value no any changed.
    so maybe the encoder is not working ?
    Kstan Simit
    Feb 03, 2021
    ok u know your encoder not detected, this is only 1 problem. however ARM not move doesn't come from encoder issue. I feel your stepper driver may not receive signal from teensy.
    You may try use multi meter test whether both input at stepper driver receive signal from teensy
    My way to test as below:
    1. switch multimeter into measure resistor mode
    2. 1 side of multimeter i put at teensy jumping wire there (jumping wire head have 1 small place show metal
    3. another side i put at stepper driver metal screw area (metal too)
    You need to test all 6/7 driver
    Just want to confirm, when you power on all stepper motor driver show green light? Assume yes cause you can't move the arm when power on. That is because driver provider power to control arm position
    0
    jasonzzpro
    Feb 03, 2021
    @Kstan Simit Yes, all the lights are green, and when the stepper motor is connected and energized, I will not be able to move the arm by hand
    0
    Kstan Simit
    Feb 03, 2021
    @jasonzzpro
    The user manually didn't explain clearly how to put cable into stepper driver. base on picture it simply slot in the jumper cable which is not right. What I did is remove plastic at head side so the stepper driver can lock/touch metal instead of plastic.
    0
    1
    jasonzzpro
    Feb 03, 2021
    In addition, what I want to ask is, after Teensy3.5 is set correctly (under normal working conditions), should there be a yellow-like light that is always on?
    Kstan Simit
    Feb 03, 2021
    no, you got burn your software into teensy and arduino?
    0
    jasonzzpro
    Feb 03, 2021
    @Kstan Simit sure
    0
    1
    jasonzzpro
    Feb 03, 2021
    I'm really desperate. This system has a lot of bugs, and it can't present problems well. But the open source system is like this
    Kstan Simit
    Feb 03, 2021
    relax bro, we helping you. Chris is brilliant guy and design this great robot arm. I learn so much from this project, however he is not pure software guy so his software may design less user friendly and not easy to identify problem.
    My web service is in progress, but require working encoder. lets fix your problem first
    0
    jasonzzpro
    Feb 03, 2021
    @Kstan Simit It took me 5 hours to reconfirm each line. It shouldn’t be the wrong wiring. But really, I don’t know what went wrong or which step was wrong.
    0
    1
    Kstan Simit
    Feb 03, 2021
    you may add my facebook account kstan@simitgroup.com
    we try zoom
    jasonzzpro
    Feb 03, 2021
    OK, i send the email to u
    0
    18 comments
