코드에 출력과 동작은 확인했는데 출력 형태에 대한 가감속 제어 문제인지 움직임이 부자연 스러움
1 comment
Like
1 Comment
Unknown member
16h
Path of Exile 2 promises deep systems, massive customization, and brutal combat—but that all comes at a price, literally. Surviving and progressing efficiently without a large pile of Chaos Orbs or Divine currency can be difficult, especially with the massive itemization and skill changes introduced in POE 2. Whether you’re a new player or a veteran entering the sequel, managing your budget is crucial for enduring the mid-to-endgame grind. Here are 25 tried-and-tested tips to POE2 Currency help you survive—and thrive—on a low currency budget in Path of Exile 2.
1. Pick a Meta or Proven Budget Build
Avoid experimental or min-max builds unless you’re prepared to invest heavily. Stick with community-tested, budget-friendly builds that don’t require multiple 6-links or rare uniques.
2. Use Free Skills and Runewords
POE 2 introduces a Rune and Runeword system that expands your ability toolkit without needing expensive gem setups. Use this system to avoid having to buy high-demand support gems.
3. Prioritize Resistances Over DPS Early
Survivability always trumps damage when you're undergeared. Cap your elemental resistances before diving into higher-tier zones. Fluctuating resistances are the killer for low-budget players.
4. Craft Using the Bench or Essences
Use the crafting bench, Essences, orbs like Alchemy and Augment sparingly to fill resistances and life on gear. Avoid blowing Chaos Orbs on rare crafts early in the league.
5. Farm the Campaign Efficiently
Don’t linger in acts trying to get perfect gear. Rush to maps or endgame zones where real item drops and currency start flowing. Use leveling uniques if available, but don’t overspend on them.
6. Loot Smart, Not Greedy
In POE 2, inventory space and looting efficiency matter. Customize your item filter to highlight high-value bases, rare crafting mats, and things like Tempered Runes.
7. Use Vendor Recipes
Master cheap vendor recipes like the Chromatic Orb recipe (RGB linked gear), or Regal recipe from full identified rares. These can give you a steady trickle of helpful orbs.
8. Sell Unneeded Uniques
Uniques that don’t suit your build can be traded for Chaos or bartered in bulk. List them on trade websites, even if they’re low-value—5 Chaos Orbs is still a huge budget boost early.
9. Flask Management Is Key
You don’t need fancy flasks to survive. A good Staunching (bleed remove) and Quicksilver flask can save your life. Later, prioritize utility flasks that don't cost much but add significant survivability.
10. Avoid Fusing for 6-links Early
Chasing a 6-link with Orbs of Fusing can bankrupt a budget player. Either use a Tabula Rasa or run a 5-link, which is perfectly viable until mid-endgame.
11. Join a Friendly Guild
Good guildmates can give hand-me-down gear, trade for lower prices, or help you run content without leeching. Don’t underestimate social networks in an economy-based ARPG.
12. Master Your Movement Skills
In POE 2, dying means losing time and potential income. Practice using movement skills effectively to dodge, reposition, and escape.
13. Target-Farm Specific Zones
Many league mechanics and zones allow targeted farming. For example, farming a specific mob type or area can drop key loot like Marauding Maces, runes, or crafting bases.
14. Run Heist, Delve, or Expedition Strategically
Some mechanics reward more per-time-investment than others. Heist is great for loot volume, Delve offers crafting mats, and Expedition can yield tremendous raw currency drops if played smart.
15. Don’t Chase Every League Mechanic
Some mechanics are currency sinks. If your gear isn’t good enough, skip mechanics like Breach, Blight, or Metamorph that require heavy investment or preparation.
16. Use Trade Websites Efficiently
Set maximum price filters when searching to avoid wasting time on overpriced gear. Use tools like Awakened PoE Trade to quickly price-check items in-game.
17. Level Alts for Gear Sharing
Level a second character to share items like gear, runes, or currency. This is especially helpful for crafting items that one class can’t easily farm but another can.
18. Use Fractured and Influenced Bases Only When Necessary
Unless your build requires them, skip expensive base types. Most builds work just fine on regular high-level bases with basic mods.
19. Prioritize Quality of Life Upgrades
Get a quick silver flask, faster casting gear, or a movement speed boot upgrade over minor damage increases. Being efficient and fast = more currency earned per hour.
20. Run Map Mods You Can Handle
Don’t blindly roll hard maps. Avoid "no regen", "reduced recovery", or "reflect" unless you know your build can handle them. Deaths and failed maps waste resources.
21. Use Prophecies or Kirac Missions
These are cheap or free ways to get better map layouts or unique encounters. Great way to get unique bosses or better loot density without using valuable Sextants or Scarabs.
22. Save Your Regrets Until You Finalize the Build
Orbs of Regret can be expensive. Don’t respec constantly while leveling—plan your passive tree in advance and use pathing tools like PoE Planner.
23. Trade Crafting Services Instead of Crafting
Instead of wasting orbs on failed crafts, find players offering free or cheap crafting services using their benches. Most top crafters offer these to boost their reputation.
24. Level Gems to Vendor or Sell
Leveling certain gems like Empower, Enlighten, or Awakened gems can yield good currency. Even non-meta ones might sell if leveled to 20.
25. Don’t Rush Red Maps if You’re Undergeared
Stay in yellow-tier maps (T6–T10) if your gear isn’t ready for reds. You can still earn good currency and build up your resources while prepping for the harder content.
Final Thoughts
Surviving and thriving in Path of Exile 2 without boatloads of currency is all about planning, efficiency, and discipline. Avoid wasteful spending, capitalize on league mechanics that suit your build, and focus on getting the most value out of each orb and item. POE 2’s flexibility allows players to craft, trade, and fight their way to endgame without being forced to spend exalts they don’t have.
Stick to these 25 tips, and you’ll avoid most of the cheap POE2 Currency pitfalls that sink low-budget players. Remember: skill, strategy, and smart trading often outperform raw gear value. Stay persistent, and even without a god-tier stash, you’ll clear the toughest content the game throws your way.
Final Thoughts
