The power supply has a potentiometer that changes the output voltage. Does this pot need to be set? The manual doesn't mention it.
You should not need to adjust the voltage output. You can use a multimeter to see what your voltage output is and adjust as desired but typically the output is fairly close to 24vdc and the drivers can accept anywhere from 20vdc up to 50vdc.
